Unable to assign a role to a user. When selecting the "Submit" button nothing happens.
The role you're assigning does not include the roles assigned to the standard Team Member role that is delivered. All roles must include standard roles delivered with Team Member. Update the role > save the changes and you should be able to now assign the new role.
How to modify, delete, or edit an existing role
Other Language Sources
