Virtualized Environments
Virtualized environments provide a significant advantage for the management of organizations’ IT infrastructure by providing control and access for multiple users connecting to applications or session-based desktops on a shared Remote Desktop Services server. Bentley Systems has validated our Subscription Entitlement Service operation in the following environments.  In many cases, there are certain configurations of the virtualized environment that may lead to a breach of our Terms of Use.  We've tried to outline the conditions that need to be met to assure that the entitlement and usage reporting of Bentley applications can continue to comply these Terms of Use, but it is ultimately the responsibility of the organization using the product to configure the virtual environment so that the Terms of Use are met. For more information, please read Important notice about use of Bentley products in virtual environments.
For virtual environments that use a remoting protocol, it will be beneficial to understand how that usage will be logged.  The behavior has been documented in  How remote usage is recorded.
If there are any questions about the user of one of these virtual environments, please contact your account manager or Bentley Support.
Virtualization Solution
Validated for use with SES-enabled products
Comments
Resources
Citrix Desktop (XenDesktop)
Yes, with restrictions
please see requirements for use located here
Citrix Applications (Xenapp)
 Frame
Pending Validation
Azure Virtual Machines
 Azure Virtual Desktop
Hyper-V
Pending Validation
 vSphere
Pending Validation
 Central Remote Desktop for HP
Pending Validation
Team Viewer
Pending Validation
Amazon Virtual Machines
Pending Validation
VMWare
Pending Validation
Windows Server OS Terminal Services
Pending Validation
OpenStack Virtual Machines
Pending Validation
Other Languaage Sources
Deutsch
