In the videos below, you will learn how to set up dimension styles for use in an organization's workspace.
| Product(s): | OpenRoads Designer, OpenRail Designer, OpenSite Designer |
| Version(s): | 10.10+ |
| Area: | Workspace, Standards |
| Creator: | Dan Eskin, Senior Consultant, Civil Engineering Success Services |
