What you need to know/request when consolidating Accounts
What is the purpose of this information?
Sometimes changes in business require you merge two separate entities into a single account.
As with any new account, consolidating accounts represents an opportunity to adopt up-to-date, supported applications (older generation applications are not eligible for support), and change your licensing model for the better (the older SELECTserver based licensing [hosted or deployed] does not provide the same opportunities for license reporting and control that Bentley's current licensing model, Subscription Entitlement Service licensing does).
Consolidating accounts also may represent the challenge to migrate all the settings previously applied to each account individually, to the surviving account. There aren't any tools to assist with this, and at no time will an administrator have access to both existing accounts prior to consolidation to document what might have been set up previously.
The site administrators from each account we'll have to work together to ensure a smooth transition
Areas affected when consolidating accounts
Subscription Type
Each account prior to consolidation may have a different subscription type. If there is a change in subscription type, it may represent a significant change in mindset for those administrators being consolidated into the surviving account regarding managing entitlements and monitoring usage, particularly if moving from a non-consumption based subscription model to a consumption based subscription model.
Contract term
All assets will have a synchronized expiration/renewall date after consolidation  Please keep this in mind when budgeting.
Assets
When accounts are consolidated, the assets that reside at each account will be aggregated as well (and in some cases migrated to current offerings) but will retain their entitlement country. Subscription analytics can be used to determine what applications your user base is actually using (and what your peak use is for these applications). Note that if changing from a non-consumption based subscription model to a consumption based subscription model, that the entitlements  available will change to reflect what is "available for consumption" in addition to owned assets.
Entitlement Management
The default access for any account is that all users under that account have access to all licenses at that account. Any customizations that were in effect for the surviving account under entitlement management (to either enable or restrict access to application licensing) will still be in effect after account consolidation. Default access in effect at the header level, will also be inherited by any new entitlements resulting from the consolidation.
License alert thresholds are not dynamic, and are manually adjusted. If account consolidation will result in a change in the quantity of entitlements for a specific products, and you have a license alert threshold license alerts set for that product, you will have to manually adjust the threshold to accommodate the new quantity of licenses available.
User Base
Consolidating accounts also means consolidating your user base. Federated accounts should a submit service request for additional assistance from the IMS team regarding a merge. Although users will be consolidated with their profiles details intact, users moved to the consolidated account will not be a member of any previously defined allocation or entitlements groups under the surviving account, nor will they maintain any of their previous roles or fulfilment contact status. A spreadsheet will be provided containing the details of the consolidated users which can be used to update the users if desired via our Bulk Update feature. You may request the consolidating users to maintain their roles, but the request must come from a co-admin or account admin of the surviving account.
Typically the user base coming from the previous account to the surviving account will have a change of email address (either format or just domain). Typically an account will have a period of mail forwarding to allow temporary usage of the old email address for correspondence. With these details in mind, non-federated accounts may make updates to their users as needed via Bulk Update to align with your directory changes. However, federated accounts should coordinate a change with Bentley's IMS team before proceeding with any changes to their users. Changes without coordination may result in lost user access and duplicate user accounts present in your IMS directory.
IMS Roles/Fulfillment Contacts
As the consolidated users have lost their IMS roles and fulfillment contact status, please be sure to reinstate any desired access to users who should maintain this access.
Domain Ownership
Prior to consolidation, the account being consolidated should release any owned domains. If the surviving account will be using multiple domains, the additional domain(s) should be claimed after consolidation is complete. If your account is federated, the IMS team will manage the domain records for the merger/split.
Licensing
Checked out Licenses
Licenses reflected is being checked out under  entitlement management may have to be released, if the user of that license is not currently associated to the surviving account, There would not be a way to release their license checked out license via Entitlement management after account consolidation.
Offline Usage
Depending on the current settings under Entitlement Management, users consolidated into the surviving account may lose the ability to activate their software (for Subscription Entitlement Service licensing). Prior to the consolidation it may be prudent to release offline restrictions on licensing to allow user 7 days of offline usage, instead of the user not being able to work (note that users working offline still generates usage towards an account). SELECTserver licensing based applications will function for at least 7 days while offline.
Licensing - Subscription Entitlement Service licensing
For subscription entitlement service-based licensing, users not listed under your account will not have access to your account's licensing. Shortly after a user has moved to the surviving account, changes to the user's policy (which controls which licenses a user can access) will happen organically every 4 hours, and the user will have access to the surviving account's licensing.
 If a user's email address has been updated in IMS, user should be informed of this change as Non-federated user will have to manually change their CONNECTION Client login to align with their new email address to allow proper access to their intended entitlements.
Licensing - SELECTserver based
While Entitlement management based licensing doesn’t maintain the concept of "Site" (for subscription entitlement service-based licensing, licenses from all sites are aggregated under Entitlement Management under an "umbrella account" referred to as Ultimate), in Bentley's contract database individual sites are still maintained. Barring configuration of the activation key, the only consequence is that an account with multiple sites under contract will have multiple SELECTserver activation keys. The keys, although different, will still activate all aggregated applications from all sites by default (the applications each key will activate can be customized as well).
Site activation keys follow the site; If a site will be moved to the surviving account, the corresponding site activation key will be moved to the surviving account as well (this will not happen by default however, only by request). If a site is redeployed to a new account's contract, the new account will also have that site's activation key. If the surviving account does not have any sites redeployed from the consolidated account, the users consolidated to the surviving account will have to use a new or pre-existing new site activation key from the surviving account (instead of the activation key they were using prior).
Prior to the consolidation, site activation keys assigned to your account should be reviewed to determine if it is still prudent or necessary to have multiple sites (and therefore multiple site activation keys) for your account, or if users from the consolidated account can easily switch to a different activation key. It is not uncommon for an account not to realize that they have multiple sites / multiple site activation keys. If it is determined that a site should be migrated to during the consolidation to the surviving account, site consolidation (and the resulting elimination of redundant site activation keys) prior to an account migration may be helpful (and easier to manage).
Account still using SELECTserver-based licensing will have to be mindful that after a consolidation, a concerted effort to use the desired site activation key is made. Enterprise management tools may make the distribution of an activation key easier. Anyone having access to your site activation key also has access to your licensing. Plans should be in place to distribute the new site activation key to your users.  The surviving account may wish to create custom activation keys instead of distributing their standard activation key, to allow more flexibility in managing their activation keys.
Before requesting an account consolidation
Double check your user base and domain ownership:
Not merging all of your users into the new account?
Want to keep your IMS roles and Fulfillment Contact status for your consolidated users?
Have a game plan for how licenses are going to be managed under the consolidated account -
Schedule a time for the consolidation to become official, and notify your users of the change.
Inform the user base of the consolidated account who their point of contact will be.
After account consolidation is complete
Under User Management
Under Entitlement Management
On user's Workstations
On user's Workstations (SELECTserver based applications)
Other Language Sources
Deutsch
