Video: Template End Condition Target - Linear Both
Product(s):OpenRoads Designer
Version(s):10.00+
Area: Corridor Modeling
Original Author:Chris Key, Bentley Technical Support Group
This video will demonstrate what is required to be set up in order for an end condition to target a Linear Elements horizontal and vertical location. The main requirements are for the Template End Condition Target to be set to Linear Both (the Linear Feature you want to target must have an Active Profile), the Linear Feature must be added to the corridor as an External Reference, and Target Aliasing needs to be set up for the profile so the end condition can target the horizontal element and the profile of that element.  This is a typical workflow for an end condition to target a known ROW location.
https://youtu.be/kfhLA4DUqrQ
