| Product(s): | OpenSite, OpenRoads, OpenRail Designer Connect Edition |
| Version(s): | 10.10+ |
| Area: | Drainage and Utilities |
Drainage and Utilities file from ORD 10.10. has been upgraded to 10.11. After upgrading some conduits are missing in Plan View. The Explorer window shows they are still present, and they appear in profile views, in 3D, just not in 2D plan view.
Please use “Synchronize Drawing” tool (see video). The synchronize command is used to synchronize the graphics to the database. This should solve this problem.
