Virtuoso Licensing
SES Licensing Landing Page
Virtuoso Subscription from Bentley's eStore - Virtuoso Licenses are pre-paid, named-user licenses that allow organization administrators to assign specific users access to the eligible Bentley (SES) CONNECT Edition products. With Virtuoso Licenses, assigned users have unlimited access to the product for the duration of the license, which is one year.
Once the purchase process is complete, the organization administrator must assign the Virtuoso License to the end user via Entitlement Management before the license can be utilized. If a Virtuoso License remains unassigned and the end-user is already licensed by SELECT covered products, all license usage will continue to be logged as “pooled” and will contribute to peak usage values.  If an end-user purchased a Virtuoso License without having any existing SELECT-covered products, the product will not activate until the Virtuoso License is assigned to the user in Entitlement Management.
NOTE: The fulfilment contact is not the same role as an Administrator - see: Difference between fulfillment contacts and administrators.
Note on the behavior change for concurrent use of an individual user's license:
Virtuoso subscription license users received a notice that, as of behavior change for Virtuoso subscriptions.  The notice communicated that, as of January 22, 2025, concurrent usage of certain Virtuoso licenses will be prohibited. There is no limit to the number of machines a Virtuoso license can be used on, but users will only be able to use the license on one machine at a time. This includes online (real-time) and checked-out usage of the licensed product. Starting these licensed products in offline mode (i.e. disconnected and not checked out) is not allowed.
If the user attempts to start the same license on a second machine (or checkout the same license for the second machine), they will be denied usage.  In newer versions of CONNECTION Client (23.0.1.25 or higher), the user will be given the machine name that is currently using the license (for example – “It seems your Virtuoso license is active on another machine. Please close the product on “machine name” and try again.”). If the user stops (or checks in) the license use on the first machine, they will be able to re-start (or checkout) the license on the second machine.  More information is available here.
Organization administrators can see which products limit concurrent use by going to the Virtuoso assignment page in Entitlement Management. Organization administrators can also monitor capped Virtuoso entitlements in Realtime Capped Virtuoso Usage Report. You can find more information about this report here.
Table of contents
How do I assign a Virtuoso License?
To assign a Virtuoso License, administrators must ensure the desired users are Connected Users. To learn more about getting users Connected, please see Connected User Setup
Once users are Connected, the administrator can begin assigning the licenses by following these steps:
Manage.Bentley.Com Portal
1) Select "Home" and click on "Assign Licenses" -
2) Choose product you wish to assign, and expand by clicking the up arrow (which will change to a down arrow) -
3) Pick which license you wish to assign, check off the box to the left of the license.
4) Locate the "Actions" dropdown and choose "Assign License"
5) Use the dialog to search for a user (by name or Email), and click "Save" to assign license.
Legacy Portal
  1. As an Admin, Co-Admin, you can go to the Subscription Services Portal and click on the tile for Entitlement Management.
    1. Virtuoso License Administrator's will need to access the Virtuoso page directly (this link can be used by admins as well) - https://connect-entitlementmanagement.bentley.com/entitlement/practitioner
  2. Click the Virtuoso tile (Main page - Your Subscription Type). If not showing, pull down the country drop-down menu along the top, and select Global.
    Alternatively, you can access the Virtuoso License from the side navigation - Settings > Virtuoso Licensing.
  3. From the list, find the Virtuoso License you wish to assign, click the "+" button on the right to the license.
  4. In a new pop-up window that appears, use the field to find the user by name or email address.
  5. After selecting the user click the 'Assign' button - the license will be assigned and the user will receive an email notification confirming the Virtuoso License.
NOTE:
If you can't assign a virtuoso license, make sure the contact you are attempting to assign the license to has a valid Entitlement Country under User Management. Refer to - Changing user(s) Entitlement Country
When can I start using my Virtuoso License?
Users can begin using their Virtuosity license only on the specified start (activation) date, as defined at the time of purchase.
  • Access to the license will not be available before this start date
  • The license becomes active automatically on the configured date
  • This behavior is expected and is working as designed
NOTE:
If you are unable to access your Virtuosity license, verify the entitlement start date first to ensure it has already been reached.
What happens if a Virtuoso License is left unassigned?
Virtuoso Licenses that are not assigned will not be used in any entitlement requests by the organization’s users or the subsequent billing of the usage generated while the Virtuoso License is unassigned. To make full use of the Virtuoso License for its duration, the license must be assigned to a user.
Reminders will be displayed to administrators in the Subscription Services Portal and Entitlement Management if any Virtuoso Licenses are unassigned.
Does an unassigned license influence/extend its expiration date?
No.
The Virtuoso License is active for a period of one year after you make the purchase and it gets processed in the system. From that moment it becomes available in the system (Entitlement/License Management portal) and is ready to be assigned to a user. In that stage it is active and unassigned until an administrator assigns it to a user - its Start Date will match the purchase/process time, and the Expiration Date will be one year from the Start Date.
An unassigned Virtuoso License has no influence on the Start Date and Expiration Date, since they are defined by the time of purchase, not by the time of its assignment.
What if I need to re-assign the Virtuoso License to another user?
A Virtuoso License can be re-assigned as many times as necessary on the first day it is assigned to a user. If it was initially assigned to the incorrect user, then changing it within that first day will require no special action.
After that initial 24-hour assignment period, the Virtuoso License will be locked for 30 days. At the end of that 30-day period, the Virtuoso License will be available for re-assignment, if necessary. Any re-assignment will start the 24-hour open user assignment period again, followed by a 30-day lock.
NOTE:
If you need to remove a user from the organization account and re-assign a Virtuoso License, to which they are assigned, make sure to re-assign the license prior to removing the user in User Management. If you remove an assigned user, Entitlement/License Management page will show "User Not Found" for the Virtuoso License and you will not be able to re-assign it. If this is the case, please open a service request, choose "Licensing and User Administration" for the category and in the description include details about removed user.
What if I need to change the email address of a user already assigned to a Virtuoso License?
If you need to change the email address of an assigned user, make sure not to remove the user in User Management - instead, change user's email address after reviewed the following articles: Bulk Operations 2.0 and How to update your Bentley profile information
If you already removed the user in User Management and the Entitlement/License Management page shows "User Not Found" for the Virtuoso License, please open a service request, choose "Licensing and User Administration" for the category and in the description include details about removed user.
How does an assigned user know they are using a Virtuoso License?
The end user, upon assignment of a Virtuoso License, will receive a notification of the assignment. The user can then activate the product either by using the Activation Wizard or by running the product.  The Virtuoso License will be indicated by the License Type in the Bentley Licensing tool\Entitlements tab.
Does the assigned user need to do anything on their machine to consume the Virtuoso License?
The end user should upgrade their CONNECTION client to version 10.00.18.x or higher. This will allow the usage to be recorded correctly as a Virtuoso license and avoid any issues with the Virtuoso usage being counted against the alerting threshold used for pooled licenses.
To check the version of CONNECTION Client and to learn how to update, please visit CONNECTION Client FAQs
How to download the software?
Only users assigned to the Virtuoso License can download the Software. Shortly, after they are assigned the Virtuoso License, they will receive an email notifying them about assigning them the entitlements, and which also includes a Software Downloads link.
NOTE:
Account administrators/Co-Administrator do not have privileges to download the software under the Bentley's eStore order, unless they are assigned the Virtuoso License.
Is the functionality the same between a Virtuoso License and a commercial license?
Within the product, the end user will likely see no difference between a Virtuoso License and a typical commercial license.  Because users with a Virtuoso License receive unlimited access to the eligible Bentley products, Subscription Entitlement Service features such as Access Controls or Threshold Alerting are disabled.
Which license is used if the account has both a Commercial and Virtuoso license for the same product?
If the account has both a commercial license and a Virtuoso license of the same product, then when it is launched by the user assigned to the Virtuoso oner license, the use of the Virtuoso license will be registered, as the Virtuoso License takes precedence over the commercial license.
Can I check out a Virtuoso License?
Yes, check-outs are available for Virtuoso Licenses. User needs to connect to the Internet at least once to check out the license in Bentley Licensing Tool. For steps, see: Bentley Licensing Tool: Checkout License Tab
Checkouts from Manage.Bentley.Com Portal
1) Select "Products" and click on The product you wish to check out a licenses for -
2) Pick which license you wish to assign, check off the box to the left of the license.
3) Locate the "Actions" dropdown and choose "Check out license"
4) Fill in the "Machine name" and "Expiration date" fields on the popup, and click "Check out"
Checkouts from From Admin Portal -
Click License Checkout Button
Fill in the blanks and click OK -
How to configure License Alerting for Virtuoso License?
There are no License Alerting settings for Virtuoso licenses. Virtuoso licenses do not generate additional usage and therefore License Alerting would not apply.
Can I use my Virtuoso License on multiple machines?
While the product may be installed on multiple machines at the same time, per the terms and conditions of a Virtuoso license, the named user may not share their license with any other user.  The license should only be used by that named user on one machine at a time.
Can I use multiple Virtuoso Licenses on multiple machines with the same user credential?
At this time, there is no way to choose which license is used on each machine.  Because the same license may be used on multiple machines, even if you have multiple licenses, you may find the concurrent use of the product for the same user is restricted.  The solution to this is to have different user IDs registered and assigned to each license.
Can I use my Virtuoso License for a V8i (pre-SES) product?
Virtuoso licenses are only available for the latest CONNECT Edition products. They are designed to utilize the Subscription Entitlement Services licensing model and are connected to an assigned email ID - older versions cannot be used.
What products are available for Virtuoso Licenses?
Most of Bentley's popular offerings are available. Please check the list under 'Software' section on Bentley's eStore.
Bentley's eStore offers virtuoso licenses for most Bentley products. These include:
  • AutoPIPE
  • ContextCapture
  • LEGION
  • MicroStation
  • MOSES
  • OpenBridge
  • OpenBuildings
  • OpenFlows
  • OpenGround
  • OpenPlant
  • OpenRail
  • OpenRoads
  • OpenSite
  • OpenTower
  • OpenWindPower
  • PLAXIS
  • RAM
  • SACS
  • STAAD
  • SYNCHRO
  • ...and more
License Assignment After Renewal – Is Reassignment Required?
When a Virtuoso subscription renews using an automatic payment method (such as credit card, BACS, or ACH), the existing license entitlements are extended instead of new entitlements being created. As a result, any licenses that were already assigned will remain assigned to the current user after renewal. Account administrators no longer need to reassign licenses each year.
Getting Started with Virtuoso Licenses
Bentley's eStore - Frequently Asked Questions
Other Language Sources
Deutsch
Spanish
Polski
Japanese
