In the 16 videos below, you will learn how to set up plan, profile, and cross section sheet seeds for use in an organizations workspace.
| Product(s): | OpenRoads Designer, OpenRail Designer, OpenSite Designer |
| Version(s): | 10.10+ |
| Area: | Workspace, Standards |
| Creator: | Chuck Lawson, Senior Consultant, Civil Engineering Success Services |
22-01 Sheet Seed Definitions - Introduction
22-02 Sheet Seed Definitions - Starter File
22-03 Sheet Seed Definitions - Backup Process
22-04 Sheet Seed Definitions - Plan Sheet Creation
22-05 Sheet Seed Definitions - Plan Sheet Settings
22-06 Sheet Seed Definitions - Plan Sheet Clean Up
22-07 Sheet Seed Definitions - Avoiding Undo Commands
22-08 Sheet Seed Definitions - Renaming
22-09 Sheet Seed Definitions - Profile Sheet Creation
22-10 Sheet Seed Definitions - Profile Sheet Recreation
22-11 Sheet Seed Definitions - Cross Section Sheet Creation
22-12 Sheet Seed Definitions - Changing the Assigned Annotation Group
22-13 Sheet Seed Definitions - Units of Resolution
22-14 Sheet Seed Definitions - Plan and Profile Creation
22-15 Sheet Seed Definitions - Plan-Plan Creation
22-16 Sheet Seed Definitions - Final Check List
www.youtube.com/watch
