Problem:
How can I shift my elements to the correct location even if my unit system got changed from feet to US survey feet?
To shift elements to the correct location.
- Changed the Working Units of all files from Feet to US Survey Feet via a batch process.
- Go to utilities > Geographic Coordinate System > From library > Select Geographic Coordinate System > and hit ok.
