| Product(s): | OpenRoads Designer CONNECT Edition |
| Version(s): | 10.00.00.120+ |
| Area: | ProjectWise Integration |
Question:
Where do I find the location of my exported workspace and dgns from ProjectWise Explorer? Where are my dms folders?
Answer:
In ProjectWise Explorer go to Tools > Options > Settings tab. Then Working Directory > When using ProjectWise Explorer. That is where PW will list the location on your local drive. You can double click on it if you want to set it to a new location.
