| Version(s): | 10.10.21.04+ |
| Area: | WorkSpace Development |
| Original Author: | Holly Herring, Bentley Technical Support Group |
This wiki links together several wikis to follow to properly get a workspace setup in ProjectWise. The following steps are benchmarks you need to follow. Once you successfully complete one, move to the next. Do not skip a step.
