| Version(s): | 10.04.00.48+ |
| Area: | ProjectWise Integration |
| Original Author: | Chuck Lawson, Bentley Systems - Senior Application Engineer |
If wildcards are used to call file names in the ProjectWise Managed workspace, the user might see slower load times while ProjectWise searches for the specified file names. The speed at which the program searches for the files can be improved by adding a variable that contains the folders in which the files reside.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
