| Version(s): | 10.04.00.48+ |
| Area: | ProjectWise Integration |
| Original Author: | Holly Herring |
This video demonstrates how to create a new project or WorkSet for use in the ProjectWise environment. There's a little more that needs to be done than a copy/paste/rename. OpenRoads Designer needs to create the dgnws so that it can burn the name of the project inside of it. This workflow shows a simple process to do this.
Workflow Overview:
