| Product(s): | OpenRoads Designer CONNECT Edition |
| Version(s): | 10.09+ |
| Area: | File Compatibility |
This video demonstrates the use of the new Civil File Manager utility added with the 10.09 update. This utility replaced the Version Checker, and a new downgrade feature was added. To learn more about downgrading, click here.
To access the tool, go to File>Civil Tools>Civil File Manager:
To upgrade files using the Civil File Manager:
1. Pick File>Open and select the folder and/or files to upgrade.
2. Pick View>Upgrade List.
3. Pick Action>Upgrade All or Upgrade All (Force)
Another new feature that is available in the Civil File manager is the ability to easily remove civil models from files. To learn more about removing civil models, click here.
Click the video below to play it. To view in full screen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
