OpenRail Ideas Portal
OpenRoads Ideas Portal
OpenSite Ideas Portal
If you have an idea for something that you believe would make OpenRoads better, please share it with us. Add your idea by selecting “Add New Idea” in the upper left corner. Please choose a category and share why you think the idea would be beneficial – specific use case scenarios often are the best way to do that. You can also share files that help illustrating it. Signed-in users can then comment and vote on ideas.
Bentley’s Product Management team will review ideas on a regular basis and classify them according to the statuses shown below. Also, the Ideas portal has the ability to send notifications to the submitter as the Idea moves through its lifecycle.
- Needs review – Idea has been created, and it is ready to be voted on. This is the default status for new ideas;
- Future consideration – Idea has been reviewed and is now in consideration for future development. Continue to vote and comment to bring the best ideas to the top;
- Already exists – We believe the idea proposed is already covered by MicroStation or other Bentley applications. We will strive to share with you as much information about it as possible in the comments section;
- Planned – Idea has been reviewed and is now being worked on. We will keep you posted about potential release;
- Will not implement – We won’t be able to implement this idea and will strive to give you as much information about it as possible in the comments section;
- Shipped – Idea has been implemented in a MicroStation release.
