ORD is unable to cut cross-sections on imported or XREFed alignments, but can cut them on alignments newly created.
Please check that you have created a 3D Model in the container file (active file) before attempting to cut cross-sections on imported or XREFed alignments
Example:
- Created a new 2d test.dgn file
- Reference in Alignments.dgn
- Trigger the 3d model creation on test.dgn by setting any terrain active or creating any alignment with a profile.
- Open the 3d model in a new view
- Created XS Named Boundaries on the referenced alignment.
- Creates XS Drawings.
