| Version(s): | 10.12.02.04+ |
| Area: | Drawing Production |
Are the Top, Bottom Clearance, and Vertical Exaggeration fields set and retained within the Sheet Seed DGNLIBs?.
Yes. When you are creating the Named Boundaries within the Sheet Seeds set the Top, Bottom Clearance and Vertical Exaggeration. When a user uses this dgnlib to create their NBs, it will automatically update with those values when that Drawing Seed is selected from the pulldown.
