| Version(s): | 10.12.02.04+ |
| Area: | Drawing Production |
This video demonstrates the order of operations when deleting sheets. First delete the Sheet/Drawing Models and then the Named Boundaries. ORD will delete the Saved Views automatically with the Named Boundaries.
