| Product(s): | OpenSite Designer |
| Version(s): | 10.07.00.56+ |
| Original Author: | Marc Blancher, Bentley Technical Support Group |
How can I set the finished floor elevation of a building pad to a predetermined elevation?
To set a building at a predetermined FFE set the minimum and maximum Z to the same elevation. The grading optimizer then knows to only grade at that elevation. If user only set one and not the other Z then that leave the optimizer to either grade up to or down to that elevation.
