| Product(s): | OpenSite Designer CONNECT Edition |
| Version(s): | 10.00.00.120 |
| Area: | Licensing |
For a full list of OpenSite Designer CONNECT Edition FAQs, please download the Fact Sheet.
Question 1: What other products besides OpenSite Designer can I run using an OpenSite Designer license?
Answer 1:
Note: OpenSite Designer needs to be explicitly on contract in order to access the legacy applications noted above. SELECT Open Access alone does not entitle these licenses.
