| Version(s): | 10.07.00.56+ |
| Area: | Drawing Production |
Problem:
When I run drawing model annotation command in a XS drawing model, the EAV cell does not get placed.
- Ensure your annotation group is pointing to a cell in the Cell Properties group. In the example below it is not pointing to any cell.
- Ensure the cell is in a directory defined by the MS_CELL variable.
- Open your annotation dgnlib and ensure that the annotation definition is a Grid annotation
- The pic below shows a typical example of how this should look
