| Version(s): | 2022 Release 3 (10.12.+) |
| Area: | Subsurface Utilities |
Question:
Is it possible to override the Longitudinal Slope of a node after placement if the node was placed with an Elevation Reference such as a Terrain of 3D element?
Answer:
There is now a Drainage and Utilities Property on the Node called Use Longitudinal Slope. You can set that to True or False.
