Insert Symbol
Product:
OpenRoad SignCAD 2023, 2024 & 2025
Version:
23.00.00.151, 24.00.00.56 & 25.00.00.53
Area:
How-to
Original Author:
Introduction:  The instructions and video below show how-to use the Insert Symbol tool in OpenRoads SignCAD.
OpenRoads SignCAD 2025
Step 1:  Activate the Text tab by selecting the Drawing > Text > Place Text tool or double clicking on existing text.
Step 2: Position the text cursor by clicking the left mouse button in the drawing window. The example below shows the text cursor inside a panel.
Step 3: From the Text tab, pick the Insert Symbol tool.
Step 4: Select a standard stacked fraction (1/3, 2/3, 1/5, 1/4, 1/2 and 3/4) to place it. Close the Insert Symbol dialog.
Step 5: If the stacked fraction is placed in a panel, press <enter> or left click to have the panel recognize the fraction and display dimensions for it.
OpenRoads SignCAD 2023/2024
Step 1:  Click on Text>Place Text. In the Place Text dialog, select the desired text font and size (ex: Font: Highway E Mod 2K and Size: 15).
Step 2: Click in the Place Text dialog, pick the Insert Symbol icon and select a symbol to place it. Press Close to exit the Insert Symbol dialog.
Step 3: Press the Place Text button and left-click to place the symbol in a panel or on the workspace.
NOTE: If placing white text on the white workspace, select the Letter Outline option in the Properties>File Properties to see the placed text.
