What is the best way to create a D1-5 Circular Intersection Diagrammatic sign in OpenRoads SignCAD?
Answer:
The D1-5 sign can be created as one panel (sign on left below) or as a multi-panel (sign on right below). The best way to create a D1-5 sign is to use separate panels and join them together into a multi-panel because this method allows you to easily align and space the different objects within the sign.
There is a D1-5 Circular Intersection Sign Course available from the OpenRoads SignCAD learning path on the Bentley LEARNserver that shows how to create a D1-5 sign.
