| Version(s): | 10.07.00.56+ |
| Area: | SIG |
2019-05 (May) OpenRoads SIG - Ramp & Gore Design:
This Special Interest Group works through two methods of designing ramp and gore areas. The video can be found here (May 2019 SIG), and you can download the dataset to follow along here (must be logged in to download). This dataset includes an ITL that contains example gore templates.
