| Product(s): |
OpenRoads Designer |
| Version(s): |
10.10.21+ |
| Area:  |
General |
Question:
How do I prepare my OpenRoads data to be published to an iModel?
Answer:
- Create a 2D container file with OpenRoads Designer.
- This container file needs to be created from the correct seed file in the Workspace used by the dataset.
- The container file needs to have the correct GCS for the project.
- Attach all needed/required reference files.
- If the reference file has a default (2D) and default-3D model, attach the default (2D) model only.
- If the file has only a 2D model(s), attach each desired model as-is.
- If the file has only a 3D model(s), attach each desired model as-is.
- Create a Civil model in the container file that results in the creation of a default-3D
- Review the hierarchy of the reference files. Be sure that ALL required files\models are listed.
- Ensure the Reference Display = ON for each reference attachment you want to show in the iModel.
- Set the 3D-Default model within the “container” file to a minimum nesting depth of 1.
Current Limitations:
Limitations: Terrains
- All terrains less than 5 million points will go directly into the iModel.
- Terrains greater than 5 million points, for performance reasons, require the use of a Context Data Share which would need to be setup for the project.
- Be aware that large terrains can greatly increase processing times.
Limitations: Subsurface
- Drainage & Utilities data that is shown in the Civil properties will be included
- The iTwin Synchronizer will also include properties from the Drainage & Utilities databases
Limitations: OpenSite
- Currently, OpenSite properties will not be included in the iModel.
Video:
www.youtube.com/watch
