| Version(s): | 10.08+ |
| Area: | General |
Questions:
How can we configure our display settings to run OpenRoads Design on a 4K monitor/high resolution/high DPI monitor?
Sometimes when opening OpenRoads on a high resolution monitor, several toolbars (such as the Feature Definition Toggle Bar) are large with small icons, or some dialog panels (such as the Create Complex Terrain) do not display at all.
Answer:
Note: This does not require a restart of Windows 10 however this does require a restart to OpenRoads Designer before changes will take effect.
* Your organization may require administrative access to perform these changes. Contact your local System Administrator for assistance.
