| Version(s): | 10.07.00.00+ |
| Area: | General |
| Original Author: | Chris Key, Bentley Technical Support Group |
OpenRoads Designer Keyboard shortcuts are prepopulated with specific key in operations. The shortcut "O" to set an origin is set to the Civil Accudraw Set Origin option. In order to set the origin when in regular Accudraw, we need to either change the shortcut or add a pop up menu to allow a selection for which Set Origin option you desire. This video will step through the process.
