Product(s): | GEOPAK |
Version(s): | 08.11.09+ |
Area: | Printing |
Original Author: | Bentley Technical Support Group |
Problem:
Where can I find my .pltcfg files in GEOPAK's folders?
You can check the location of your .pltcfg files under these two configuration variables:
MS_PLTCFG_PATH - search path for plot configuration files,
MS_DEFAULT_PLTCFG_FILE - default plot configuration file.
Most likely you will find your .cfg files under the following path: C:\ProgramData\Bentley\PowerGEOPAK V8i (SELECTseries)\WorkSpace\System\pltcfg.
_______________________
