Video: How to extract Civil element Properties through item types
Product(s) :Open Roads/Site/Rail Designer
Version(s) :10.12 +
Area : Item Types, Expressions
Starting from Open Roads/Rail/Site 2022 R 1, using the Expression Builder, you can extract the civil properties by copying the EcExpression from the element property dialog box.
Note that you need to set the variable  civilpropertyecexpression = 1
www.youtube.com/watch
