| Product(s): | OpenRoads Designer Connect Edition |
| Version(s): | 10.09+ |
| Area: | Model Analysis and Reporting |
The video below discusses the use of the "Custom" volume option to model volume calculations for overexcavation and Moisture Density Control (MDC) scenarios.
NOTE: Beginning with the 10.10.20.78 released, the "Custom Display" options where changed to either "Both" or "Remove Only". Please also view this video explaining the new options: New "Custom Display" options
