| Version(s): | 10.00.00+ |
| Area: | Report |
Question
Is it possible to Embed Civil Reports output within the drawing?
Answer
Save the report as xlsx and open it.
Select the cells that you want to see in the drawing and copy it.
Open the Drawing model, right-click on your mouse button and hold it for a few seconds to get a pop-up window.
Select “Paste from Clipboard” choose “Paste as” Embedded and “Method” Corner.
Select the location and drag it to another corner to place the report.
Now you should be able to see the report in the sheet model as well.
