| Version(s): | 10.08.01.33+ |
| Area: | Drawing Production |
This video demonstrates using OpenRoads Designer to create a cross section set which stacks cross sections on your sheet starting at the top of the page moving downward.
Note: For 10.08.01.33, it is required to have a sheet seed with the first boundary on top, however, beginning in the 10.09 release, a separate sheet seed for top-down will not be necessary.
Set variables CIVIL_CROSSSECTION_STACK_TOP_DOWN = 1 and CIVIL_CROSSSECTION_BOT_MARGIN to your bottom margin value.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
