| Version(s): | 10.00.00.120+ |
| Area: | Basic Settings |
| Original Author: | Marcus Blake, Bentley Technical Support Group |
When creating the cross sections sheets, only one cross section per sheet is created. Why?
Possible causes:
# Cross Section Sheet Spacings and Margins Settings
# Units are in Sheet master units(feet or meters)
# NOTE: ALL 4 variables must be set for them to be used.
# CIVIL_CROSSSECTION_RT_TO_LT_SPACING - If multiple cross sections can fit in the same
# row moving from left to right, this variable defines the horizontal spacing between
# the adjacent cross section boundaries.
# CIVIL_CROSSSECTION_TOP_TO_BOT_SPACING - If multiple sections can fit in the same
# column moving from bottom to top, this variable defines the vertical spacing between
# CIVIL_CROSSSECTION_SIDE_MARGIN - Each cross section is tested in the horizontal direction
# to determine if it will fit on the sheet and still allow this variable to be met. This
# distance is measured from the right edge of the cross section clipping boundary to the
# right edge of the sheet model edge. If the computed distance is less than this variable,
# a new cross section sheet model will be generated for the next cross section.
# CIVIL_CROSSSECTION_TOP_MARGIN - Each cross section is tested in the vertical direction
# This distance is measured from the top edge of the cross section clipping boundary to
# the top edge of the sheet model edge. If the computed distance is less than this variable,
# a new column of cross sections will be started if adequate space is available.
# Otherwise, a new cross section sheet model will be generated for the next cross section.
