| Product(s): | OpenRoads, OpenRail, & OpenSite Designer |
| Version(s): | 2023+ |
| Area: | Drainage and Utilities |
New functionality to calculate spread width and depth at a ditch inlet that receives flow from an upstream channel, and calculate the hydraulic results for the channel.
