| Product(s): | OpenSite, OpenRoads, OpenRail Designer Connect Edition |
| Version(s): | 2023+ |
| Area: | Drainage & Utilities |
It is now possible to designate what OpenFlows license to default activate when opening an Open Civil product. To accomplish this, you would add a configuration variable to your workspace.
The configuration variable is SUDA_DEFAULT_LICENSE. You can set it to one of the following:
The variable is not case sensitive.
Once the variable is active when you open the software it will use that license each time. You no longer need to go to the Drainage & Utilities workflow, select the Tools Tab and then select what license you want to activate.
Note: If the variable is not used then the default behavior is to use the StormCAD 100 inlets license.
Video: Automatic License Activation
