| Version(s): | 10.00.00.120+ |
| Area: | Training |
Training Links:
Use the links below to view training courses available on the LEARNserver. There you will find videos, presentations and datasets to download.
*Migrating to OpenRoads Designer CONNECT Edition* In this Learning Path, you will learn about the migration path options for moving to OpenRoads Designer from InRoads, GEOPAK, MXROAD, and PowerCivil SELECTseries 2, 3, and 4 software. Learn what can be done, the minimum that must be done, and what Bentley resources and services are available to assist you.
Roadway Design & Modeling - Fundamentals This learning path is intended for new users just getting started with OpenRoads Designer. It will provide you with the basic skills for roadway design and modeling.
Roadway Design & Modeling - Intermediate This learning path is intended for users that have completed the Roadway Design & Modeling Fundamentals learning path and would like to learn more detailed tools and processes.
OpenRoads Designer for Existing v8i SELECTseries 3 or 4 Users This learning path assumes SS3 & SS4 users are already familiar with basic OpenRoads Technology concepts such as terrains, geometry, superelevation, templates and corridors. It is intended to refresh existing concepts and teach new features and workflows.
Best Practices This learning path contains video presentations on OpenRoads Designer Best Practices.
Terrain Modeling This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Terrain Modeling.
Geometry This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Geometry.
Corridor Modeling This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Corridor Modeling.
Model Detailing This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Model Detailing.
Drawing Production This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Drawing Production.
Civil Cells This learning path features courses that will teach you how to use and apply civil cells and also how you can create civil cells.
Drainage Modeling This learning path introduces you to the software interface and general tools, and then focuses on drainage modeling. You will learn how to use the Drainage and Utilities tools to layout and import networks, analyze and design a network, create reports, plan and profile sheets, and cross section sheets. The analysis and design tasks in this path use steady-state hydraulics and hydrology, which is often referred to as the Rational Method.
Drainage Hydraulics This learning path focuses on drainage hydraulics, starting with steady-state (Rational Method) design and analysis, and then moving to unsteady-state analysis, to understand the advantages that it provides. You will learn how to use the Drainage and Utilities tools to setup rainfall data, design, optimize, and analyze a drainage network, and then move on to unsteady-state analysis, and design ponds. In order to successfully complete this learning path, you should have already completed the Drainage Modeling learning path.
Utilities Modeling This learning path introduces you to the software interface and general tools, and then moves into courses focused on utilities modeling. You will learn how to use the Drainage and Utilities tools to import utilities from graphics, and to detect and manage conflicts between the utilities
Survey This learning path contains hands-on courses and various Learn Conference, Special Interest Group (SIG) and Tech Talk videos related to Survey.
Geotechnical This learning path contains hands-on courses for gINT Civil Tools.
Reality Modeling (Visualization) This learning path contains hands-on courses and online presentations related to the Reality Modeling tools available inside of OpenRoads Designer.
Workspace Setup. These videos will guide you through setting up an OpenRoads Designer Workspace including migrating data from existing V8i workspaces.
