Cannot Select Points for Point Controls
Product(s):OpenRoads Designer
Version(s):10.05.00.30
Area: Corridors
Question:
After verifying that my points do exist in my template, I cannot select the desired points from the Point Controls, template point dropdown, they are not listed.
Answer:
Ensure that the points to be controlled in the template do not have Feature Name Override applied to points to be controlled.
Point Names that appear in red indicate that Feature Name Override has been applied, these points will not appear in the points dropdown.
If you point in question DOES NOT have feature name override applied, this could be an issue related to a bug. The workaround for this is to create the Point Control with a different point and then open the corridor objects dialogue, select point control and then it will list all points there.
