| Product(s): | OpenRoads Designer, OpenRail Designer |
| Version(s): | 10.10+ |
| Area: | Drawing Production |
When I change settings in my design model, those changes are not reflected in my drawing model.
In the current versions of OpenRoads and MicroStation, the model that controls the settings of a drawing model can change. When your drawing model seeds are set up to use the "Synchronize View = Settings from Design Model" setting, the "Default" design model will initially control the view settings in the drawing model. However, once a "Multi-Model Views" named view group is added to the file, the Settings from Design Model now looks to the Multi-Model Views view group for the view settings.
The video below demonstrates this behavior, and highlights 3 recommendations for creating plan sheets:
1.) Always use a "Container" file to create sheets
2.) Keep the Default design model as the model displayed in View 1
3.) In the Container file, do not create any additional Named View Groups. Instead, be in the habit of using "Multi-Model Views" when switching back and forth between the drawing model and design model.
(Note: The video below primarily discusses the use of the Settings from Design Model for plan drawings. For Cross Sections, the user will want to set View 1 to the 3D model, as discussed in this video: Video: Using Settings from Design Model option for Cross Sections)
