Product: |
OpenRoad SignCAD 2023 & 2024 |
Version: |
23.00.00.151 & 24.00.00.56 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
Step 1: In OpenRoads SignCAD, use an existing standard sign or other sign file as a template.
Step 2: Create a text file in Notepad. The top line of text in Notepad should match the sign template wording (ex: EXIT 44). Words in the sign are separated by tabs (ex: EXIT<Tab>44). Press <Enter> at the end of each line. Save the text file.
Step 3: Pick the File tab to go to the Backstage and pick Import > Import Street Names.
Step 4: In the Open dialog, browse and select the TXT file to import and press Open.
Step 5: Pick Fit View to see all of the signs generated from the sign template and imported TXT file.
