How to change the default setting on the Feature Definition Toolbar for persist snaps?
Product(s):OpenRoads Designer/ OpenRail Designer
Version(s):2023+
Area: General
Question:
How to by default enable or disable the persist snap from Feature Definition Toolbar?
Feature Definition Toolbar persist snap
Answer:
Option to set default value for persist snap is available in the user preference settings.
Go to File > Settings > User > Preferences > View Options - Civil > Toggle Commands
and set the value for Persist Snaps to True or False as required.
green
