The OpenRoads SignCAD learning path has the following courses with videos to help you learn and use the OpenRoads SignCAD software:
Overhead Advance Exit Sign with Fractional Mile (2020 R2)
In this course you will learn how to create an overhead sign with 16” E Mod legend, a standard fraction and a top aligned row containing two state route markers.
Overhead Exit Only Panel with Dividing Line (2020 R2)
In this course you will learn how to create an overhead exit panel with an Exit number panel and EXIT ONLY panel assembled into a multipanel arrangement.
Interchange Crossroad Sign LA (2020 R2)
In this course you will learn how to create a directional sign at an interchange/intersection both as a single panel and as a multipanel.
Truck Lane Sign 2D 51 (2020 R2)
In this course you will learn how to create a multipanel sign with two panels of different colors that are attached.
OpenRoads SignCAD Basics (2020 R2 & 2023 R1)
This course will introduce you to the OpenRoads SignCAD software menus and tools and the three main concepts of arrangements, alignments and spacing.
Overhead Arrow Per Lane Sign TX-04 (2020 R2)
This course will guide you through the steps to create an overhead arrow per lane sign using multipanels.
Street Name Sign D3-1 (2020 R2)
This course will guide you through the steps to create a street name sign with multiple size text and use it as a template to create other signs.
Distance Sign with Split Lines TX-09 (2020 R2)
In this course you will learn how to create an interstate sequence sign for multiple interchanges.
D1-5 Circular Intersection Sign (2020 R2)
This course will guide you through the steps to create roundabout signs using the roundabout arrows in the US2009 standard.
Overhead Exit Only Panel with Exit Number Panel (2020 R2)
In this course you will learn how to create an overhead exit only panel with an exit number panel. This course will guide you in creating and assembling multipanels.
Overhead Advance Exit Sign with Left Exit Plaque OH (2020 R2 & 2023 R1)
This course will guide you through the steps to create an overhead advance exit sign with a left exit plaque.
Lane by Lane Assignment Guide Sign (2020 R2)
This course will guide you through the steps to create a lane-by-lane assignment guide sign.
E365 OpenRoads SignCAD Fundamentals (2020 R2 & 2023 R1)
