| Version(s): | 10.04+ |
| Area: | Survey |
This video demonstrates the ability of OpenRoads Designer Survey to draw planimetrics based on the attribute values collected in the field.
For Feature Definition Name, only the name is required (not the full path to the feature definition).
For the Element Template Override String Value, the full path to the element template is required, for example: "Survey\Point\Control\E_Surv_IronRod".
