Video: Sheets Using Nested References 99
Product(s):OpenRoads Designer
Version(s):All
Area: Drawing Production
Original Author:Derricke Grey -  Director, Product Management
Problem:
Users often express concern that the default Nesting Depth in Drawing Models of 99 may cause unwanted data shown in the sheet, and therefore will often manually edit the Nesting Depth to some lower number.
The video below demonstrates why a Nesting Depth of 99 in the Drawing Model is the preferred default value, and setting the value too low could prevent some data from being displayed.
www.youtube.com/watch
