| Product(s): | OpenRoads, OpenRail, & OpenSite |
Problem:
My CE product crashes whenever I try to load a WorkSpace/WorkSet that is synced on OneDrive.
It is fairly common to store project data on OneDrive, but it is possible to run into issues while using a synced configuration. If this happens, stop the sync in your OneDrive settings or on the Microsoft 365 website, and then confirm the configuration will load. If it does, try re-syncing with OneDrive from the Microsoft 365 website. If not, the issue wasn't OneDrive, and you'll need to keep investigating.
