| Product(s): | OpenRoads Designer, OpenRail Designer, OpenSite Designer |
| Version(s): | CONNECT |
| Area: | Platform commands, Stencil Tool |
We recently encountered this problem in a support case. I need to add pavement markings to a corridor model by creating a Stencil Model. In this corridor model I have different locations with bridges. The stencil model appear to be working in some sections except for some template drops on bridge locations.
The issue was resolved after tightening the template drop interval
and corridor template drop multiplier
then reprocessing the corridor. After doing so, we used the stencil command and the lane marking appeared as desired.
