How to get details from the log?
Logging Errors TechNotes Topics
The following article describe how to use the log files and increase the level of details being logged.
By default, the "Conceptstation.log" file is located in your temp folder such as: C:\Users\YourName\AppData\Local\Bentley\Logs.
To change the level of details being logged during a session, edit the logging.config.xml file located in your installation directory, such as:
C:\Program Files\Bentley\ConceptStation\logging.config.xml
Open logging.config.xml file. At the bottom of the file, change the priority value to "DEBUG" (default is "ERROR") (See attached Screenshot).
Save the file and restart OpenRoads ConceptStation.
