| Version(s): | 10.00.00.120+ |
| Area: | Corridor Modeling |
| Original Author: | Alan Benger, Bentley Senior Application Engineer |
This video gives an example using an Overlay/Stripping component to model Topsoil Stripping. Variable depths can be specified using Parametrics Constraints defined in the topsoil component.
