| Version(s): | 10.10+ |
| Area: | Corridor Modeling |
In this video you will learn how to extend pavement sublayers to ditch fore slopes / fill slopes by using the horizontal min/max constraints. In shallow cut or fill areas, this method will also demonstrate how to “box off” the sublayers.
