| Version(s): | 10.06.00.38+ |
| Area: | Corridor Modeling |
| Original Author: | Chris Key, Bentley Technical Support Group |
This video demonstrates the new Void option when creating a closed component within a template. In order for a void to be valid, it must be a Closed Shape component AND it must have a Parent component assigned. The 'Void' option will not be available until a Parent component is associated to the component you wish to create a void from.
